Drag Racing Tech
Strange SA Rear Shock Adjustment
Old 05-10-2009, 03:47 PM
solocus's Avatar
Default Strange SA Rear Shock Adjustment
Did a search and found a little bit of info but I'm looking for a recommended adjustment settings and should I make the drivers side rear shock a bit stiffer. Car is full weight stock height with UMI TA, LCAs, LCA Relocation Bkts, PHB, stock front shocks. TIA
Old 05-11-2009, 06:09 AM
LS1Tech Sponsor
MADMAN's Avatar
Always set your shocks the same on the rear. I would start around 5 and adjust from there. You will have to play with the settings till you find what works the best for your car.
__________________
www.madmanandcoracing.com
225-343-9029
Old 05-11-2009, 07:55 AM
solocus's Avatar
Thanks Madman!
Quick Reply: Strange SA Rear Shock Adjustment
