New LS1 Owners - Newbie Tech - k&n air filter do i need the gasket that comes with it
99 ss
05-10-2009, 05:07 PM
hay guys just wanted to know if i need the gasket that come with the air filter its on a camaro ss will i lose any gain if i dont use it or can something go wrong with it if i dont use the gasket . do i even need it . thanks
If you have just the filter call up K&N and they'll send you a new gasket under the million mile warranty.
demarco313
05-10-2009, 08:02 PM
you totally missed what he was tryin to say. He is asking about the gasket and if he needs to use it and if he doesnt will he lose any hp lol
But no you dont need it and you wont lose anything from it. You can just ditch it if you want to
99 ss
05-11-2009, 01:23 AM
ok thanks guys i was just wondering but i fell better now that i dont need that gasket
Mr Incredible
05-11-2009, 08:55 AM
It came with a gasket for a reason. It is required to have the appropriate tight fit.
If you don't use it you run the very good chance of ingesting unfiltered airflow from the wrong side of the filter.
Why would you not want to use it?
99 ss
05-11-2009, 06:05 PM
will couse i put the gasket on before and it came off and it sucked it up in my ram air
I don't have a gasket on my K&N, I bought it used with my airbox though so idk
metalmechanic
05-21-2009, 02:04 AM
WTF Whuy are there so many frekn questions about this gasket, does anyone have an idea what a gasket does?
Mr Incredible
05-21-2009, 12:53 PM
I put mine in the channel where the lid fit into, IIRC. I cleaned the channel out and then hit it with a little solvent first. I can't see how it could have come out. Mine's been in there for several years now.
Regardless, if yours was anything like mine, it was way too loose without the stick-on gasket. I'd go back to a paper filter until you can figure it out or verify that your application does not require it. Your call...
99 ss
05-21-2009, 05:32 PM
yea i just got me a new filter just to be safe i got a black wing there is no gasket with that one
02SLPfirehawk
05-21-2009, 05:54 PM
I put the gasket on mine just cause I wasn't sure... tho I'ma newb so who knows if I am right lol.
greezy
05-21-2009, 07:30 PM
it takes longer to post this question than to put on the gasket. USE IT
metalmechanic
05-25-2009, 11:39 PM
clean the top of the airbox really well of oils and debris so the gasket will stick good, remove it from the engine, to do a really swell job
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
