Strange 12 Bolt Prostar Studs???
Old 05-10-2009, 05:09 PM
jonm3456's Avatar
Default Strange 12 Bolt Prostar Studs???
I have the Strange 12 Bolt installed in my 01 SS 6spd. I also have a set of Prostars 15 x 10 7.5" bs. The wheel studs that came with the 12 bolt only stick out 1 1/2" past the axle flange. I am going to need at least another inch of stud for the wheels to bolt up. Does anyone know the correct wheel studs to use to correct my situation? Has anyone else come across this problem???
Old 05-11-2009, 07:25 AM
ss1
ss1's Avatar
Are you going with the 12mm studs, or the larger 1/2" ones? Your axles should have provisions for both thread sizes. Strange A1026's are 3" long 1/2" studs and should do the job for you.
Old 05-11-2009, 04:04 PM
jonm3456's Avatar
Thanks a lot. I was unaware that Strange made a 1/2" stud that was screw in and 3" long. Before I was using the 12mm x 1.50 RH OEM style. That just means another set of shank style lug nuts for the ProStars to bolt up...
It's only money, right???
