799 heads on a stock LS1
Posted this in the wrong one...But got a set of these from my buddy and wondering what I need to get the most out of em. Going on a stock LS1 with about 168k miles on it. In a B4C S.C. hp car...Heads came off a 5.3 truck...Let me know what you think
Also not trying to hijack the thread but can someone also tell us what head gaskets to use? Would you buy head gaskets for the new 799's your installing or for whatever year LS1 you have?
I have heard nothing but good things about these heads..I don't mind porting it at all I just want to know what would be the best CC for it..A little more info about it also..Probably not going to do much besides the head swap..some long tube headers a fast 90 intake/90 tb probably the rumbler tsp exhaust...maybe a cam but not sure about it or not..going to be a basic car maybe something to play around in the street with but I drive a hour to work and hour back..so nothing to bad until i find a better work vehicle
799 are the same as 243, the Z06 uses different valves which are lighter but aren't as durable with stiffer springs.
The 799 are installed on 5.3 HO motors but they also install them on a bunch of motors.
Well then I probably will go ahead and get the cam also. But I've already got the heads..got a pretty good deal on em I thought (250)..Just want em to be ready to slap on when I have the money for the rest of the work...What springs etc and what CC to port to? Also what head gasket should I use?
799's are pretty much bargain 243 heads but are sand cast not permanent mold. I bought a set for $150 they are same CC as the 243s-same valve sizes too(stock 5.3 do have smaller valves-just not these) - just need to upgrade springs for a bigger cam. Porting would be good to do while theyre off-It'd be nice if you could get them CNC ported for 3-400$ - good budget set of heads but add the cam at the same time
