Question about road comfort
Hey all, I am running a Strano/Koni setup in the glorious land of NY/NJ. The potholes have simply become too much to bear and I need to switch my 18" wheel setup. My buddy has the same setup with 16" wheels and it is significantly smoother. My question is this: Will a 17/18 setup solve my problem or should i opt for 17" all around? I assume the grunt of the problem (harshness on bumps of course) is from the front end, so this should solve it. Has anyone done this before or experienced similar results? Thanks
I think you need to worry more about the profile of the tire more than the size of the wheel if you're worried about comfort. I mean if you go 17" and use a tire with the same profile as your 18" wheel had, you'd prob feel almost the same amount of road harshness. Your friends 16" wheels feel better probably because his tires have a ton more sidewall than your 18" tires.
i set my tires around 35 and i will try lowering the konis one sweep and see if that helps.
What brand/model/ size tires you have on there now?
The reason I'm asking is that my falken 452s 18s ride very similar to my factory 16s, I can notice a slight increase in impact harshness from the 16s to the 18s , but that's it.
It could very possibly be just the brand/model of tire, not the fact they're 18s.
Front:
Edelbrock front IAS shocks with Hypercoil 600 lb.in. springs and "upper mount mod".
Global West upper control arms delum bushings in the factory control arms, UMI front LCAs, Hotchkis front sway bar.
Rear:
Edelbrock IAS shocks, GlobalWest rodend PHB, DKT LCAs with Johnny Joints.
BMR LCA relocation brackets, Factory bumpstops cut down 1", A.R.T. Coolride Air spring kit, Hotchkis rear sway bar.
Also I'm running 275/35/18s up front and 275/40/18s rear, with Falken 452 tires.
Rear:
