Need help about headlight
Old 05-10-2009, 07:17 PM
BlueTA99's Avatar
Question Need help about headlight
Yesterday i had to jump start my 99' TA
later that night, when i turned on my headlights ON... the passenger headlight did not pop up... so i had to open it manually for the night. Once i got home i turned off my headlights off and once both headlights were down it makes a noise coming from the headlight motor on the passenger side.... everything was working perfectly never had a problem since i bought it (in 2006)... it all went bad when i jump started my car
is it still fixable? or is it time to buy a new headlight motor?
help and advice would be appreciated
Old 05-10-2009, 07:19 PM
neutron82's Avatar
might try checking all you fuses... not sure if there are any for the headlight motors but that's where i would start
Old 05-10-2009, 07:22 PM
BlueTA99's Avatar
i check the fuses everything is ok
Old 05-10-2009, 10:43 PM
95TAJade's Avatar
new headlight motor time...or you could try those brass gears. I didn't have such great luck with them, but you might.
Old 05-10-2009, 11:26 PM
406malibu's Avatar
I think I read that the gear only uses about 180 degrees, and you can flip the plastic ones around and buy some more time. Not a 100% on this, but thought I would throw it out there.
Old 05-10-2009, 11:35 PM
foreverzero's Avatar
^ you should be able to flip the gears, or its new headlight motor time....i replaced one in every thirdgen trans am i owned, lol, thats why i have a camaro now!
Old 05-11-2009, 01:02 AM
OMGWTFBODY's Avatar
All info can be found here:
http://www.bfranker.badz28.com/headlightfix/
Personally I like: lifetime warranty O'Reilly's headlight motors.
FTW.
BTW, when reinstalling, cleaning the threads on the bolts/nuts with a tap and die saves a GOOD hour of cussing.
Old 05-11-2009, 01:16 AM
hitmanws6's Avatar
mine was like that when i bought my ta. i got a new motor and its working great
Old 05-11-2009, 08:53 PM
97T/A LT1's Avatar
I flipped mine 180 and the problem went from the down postion to the up position. I pulled the plastic gear off the metal hub and rotated it 90 degrees, of course I don't remember now which way. I haven't had any trouble since, it's probably been 2 years.
Don't forget to hammer down the metal tabs holding the end of the motor on. They get loose and allow extra play between the gears, that's why they strip in the first place.
