I cant get the level of the fluid to be right.
I bought the car from dealer, they drop the pan and filter, he having trouble to get the level to hit the hot mark, I dont know what happent, but today I decise to check, I pull the dipstick out, wipe off with clean shop tower, put it back in, and pull out, I can see the red fluid around the warm mark , but then above it is kinda wet it way above the hot mark, im confuse !! im affaird he over fill it, the car shift very smooth ( it not very very smooth, i can feel it get into each gear ).
Update, this morning I check the level again ( COLD ENGINE ). and it way over the hot mark, so I pump 2 quart out and it drop back down to low mark . My question is.
can I drive the car now, to get the tranny get hot, so I can check the level. even the dip stick show low level when cold.
yes you can drive it just take it easy and dont beat on it. If I remember correctly you just have a low mark and a cross hexed area on the dipstick. If that is the case then you want to fill it until your fluid level (cold) is at the bottom of the cross hexed area. Once you have driven it and got the fluid hot, then it will expand and move into the cross hexed area.
