Rod Knock on 05 C6?
Old 05-10-2009, 11:21 PM
cvccbum's Avatar
Default Rod Knock on 05 C6?
I just bought an 05 c6 and the dealer left it two quarts low. On my way back I started hearing noises already.
Heres the noise i'm getting now:
http://www.youtube.com/watch?v=nZhGCUP1h7g
It seems like you cant hear it inside but unless the car is engaged.
Is this a rod knocK?
Old 05-11-2009, 12:11 AM
killagt's Avatar
sound like lift tick to me, did you put 2 quart back on ? hell I TAKE IT BACK TO THE DEALER ASAP.
Old 05-11-2009, 12:54 AM
cvccbum's Avatar
Yeah, has lifter tick too (common). I changed the oil after adding 2 quarts. I'm worried bout the deep tone'd ticks in there.
Old 05-11-2009, 01:32 AM
killagt's Avatar
What oil and filter do you use ? like I say early, if I was you, I take it back right after I find out it 2 quart low.
Old 05-11-2009, 11:07 AM
cvccbum's Avatar
The noise came before the oil change, I added Mobil 1 5-30w when I found it low.
And the oil change was Mobil 1 5-30w, AC delco filter. Didn't help any
Old 05-12-2009, 09:09 AM
duh
duh's Avatar
sounds like big issues to me....take it back and let them deal with it!!
Old 05-12-2009, 10:13 AM
killagt's Avatar
btw, ac delco dint make good filter any more, actually they made by champion lab encore with cheap quality, I do use wix ( napa gold ) or mobil 1 , and nothing else. good luck bud
Old 05-12-2009, 10:19 AM
Fast Bird's Avatar
that is a knock for shure dude, good luck with that dealer and hopefully they dont screw you.
Old 05-12-2009, 08:45 PM
LS1vazquez's Avatar
It's a knock.
Old 05-12-2009, 08:49 PM
chrisdacarnut's Avatar
My 05 C6 got a split cylinder wall at 30K miles letting coolant in. Started knocking afterwards.
Old 05-12-2009, 09:53 PM
LS1vazquez's Avatar
What? How did that happen? Not from normal operation I hope.
Old 05-24-2009, 09:28 AM
Not sure, I had only had it 2 months before it happened. I never got a chance to abuse it.
