cam swap, do i have everything?
Old 05-11-2009, 12:15 AM
firechicken76's Avatar
Default cam swap, do i have everything?
I was going to do heads and cam, but can only afford a cam swap right now, so heres what i have and what i need, if theres anything else could someone chime in?
check list for cam
Mti x1 cam
Comp 918 springs
Hardened pushrods
what i need
ls2 timing chain
gasket kit
Tune
I have low miles on the engine (02 ls1) so im going to wait till i do the heads to do the lifters, so i dont have to pull the heads off twice.
lt's, ud pulley, ls6 intake, ported tb
think ill hit 390+?
Old 05-11-2009, 01:16 AM
LilJayV10's Avatar
Here's a good thread discussing a cam swap
https://ls1tech.com/forums/generatio...wap-price.html
Old 05-11-2009, 02:40 AM
slmdLS1's Avatar
...coolant?
Old 05-11-2009, 10:02 AM
might as well change the oil too right?
Old 05-11-2009, 10:08 AM
blueshark123's Avatar
What about lifters?
Old 05-11-2009, 10:28 AM
Originally Posted by blueshark123
What about lifters?
"I have low miles on the engine (02 ls1) so im going to wait till i do the heads to do the lifters, so i dont have to pull the heads off twice"
Old 05-11-2009, 10:54 AM
TooLateVTEC's Avatar
What about lifters?
Feel free to read his entire original post !
I would say you need an oil change and some coolant on top of the list you have.
Also, you need a valve spring changing tool !
Dont forget to look up the rocker arm torque specs, I THINK they are 22 ft.lb but im not 100%.
Old 05-11-2009, 11:42 AM
Banned Village Idiot
LS1BLKSS's Avatar
you need the harmonic balancer bolt
http://www.hinsonsupercars.com/p-621...lt-ls1ls2.aspx
maybe some cam lube
and a pulley remover
Old 05-11-2009, 11:45 AM
fauslpss's Avatar
If you take the oil pump off dont forget the O-ring.
Old 05-11-2009, 11:50 AM
TXZ28LS1's Avatar
check list for cam
Mti x1 cam
Comp 918 springs
Hardened pushrods
what i need
ls2 timing chain
gasket kit
Tune
think ill hit 390+?
you should definitely be around the 390 range with that cam. i made 395 stock heads on my auto with that cam and no pulley.
Old 05-11-2009, 12:25 PM
ive got a 9" sucking power though...
thanks for the info on the harmonic balancer bolt, cam lube, coolant etc! very helpfull. and the oil pump O ring
Old 05-11-2009, 08:37 PM
called up texas speed, they said there cam gaskit kit comes with harmonic balencer bolt, cam lube, etc, so looks like ill just get that and the ls2 timing chain kit, also does anyone have a set of locks for some 918 springs? i mean like 2 half pieces for one spring, i bought some springs on here from a guy, he did a horrible job packaging the stuff and those were missing, and do i need shims? because i only got half of them.
