Gauges HELP
Old 05-11-2009, 09:19 AM
minytrker's Avatar
Default Gauges HELP
I need to know how to hook up the stock gauges on a 72 formula. I have the factory sending units installed already and the hooked up what I thought was the right wires but the gauges stay pegged out. I also need to know what wire to run to the pcm for the stock tach to work.
Old 05-11-2009, 09:51 AM
RE AND CHERYL's Avatar
Do you have a good ground fromt eh engine to frame?
I beleive pin 10 from the PCM is the tach signal. The wire is white for sure.
Re'
Old 05-11-2009, 12:02 PM
minytrker's Avatar
yeah its grounded. I got the tach working but the water temp and the oil pressure are still pegged out. I have the right wire hooked up for sure on the coolant gauge.
