Driveshaft for stock 10 bolt to TH 350
Old 05-11-2009, 11:18 AM
ping2day's Avatar
Default Driveshaft for stock 10 bolt to TH 350
Does anybody know the driveshaft length and joints i need for my TH350 to my stock 10 bolt and what brands did you go with? Aluminum, Chrome Moly? Thanks
Old 05-11-2009, 11:45 PM
LS1Formulation's Avatar
You have to measure it once the trans is in the car... every car is different.
Old 05-12-2009, 04:17 AM
EPP
EPP's Avatar
I agree, I'd wait until it is in the car. You can use the chart at this link to get the correct dimension. http://www.exoticperformanceplus.com....html?item=827 Bob
Old 05-12-2009, 07:31 AM
ping2day's Avatar
Ok thanks for the reply. I just wanted to minimize my time off the track. I will wait until i get the new trans in. I talked to strange also they said i have to use a conversion joint on the 10 bolt.
Old 05-12-2009, 12:42 PM
Jawsgear's Avatar
Not necessarily, depends on who builds the driveshaft and what size end yokes are installed on the tube.
Jeff
Old 05-12-2009, 02:42 PM
ping2day's Avatar
Thanks for the advice. I will have to go with a small one 1310 for the 10 bolt correct or can i replace the ujoint and everything on the 10 bolt side to the larger 1350?
