Meth and AFR question
Old 05-11-2009, 07:17 PM
mike13's Avatar
Default Meth and AFR question
I made some changes to my turbo car which increased airflow causing the car to run lean. We didn't make any fuel changes just turned on meth injection and it richened the motor right up. Mixture of 50/50 single nozzle cooling mist vari-cool II system.
Does methanol really add that much fuel? At 8lbs boost we aborted the run because the afr was 13.8 turning on the meth/water injection we we're right back in the 11.5 afr range.
Old 05-11-2009, 07:22 PM
BigRich954RR's Avatar
yup meth is fuel my car with out meth would run in the 16. A/F i run 100 % meth
Old 05-11-2009, 07:32 PM
mike13's Avatar
what size nozzle? I'm running 500cc/m. I was really surprised how much richer the a/f got by adding the 50/50 mix.
Old 05-11-2009, 07:33 PM
DeltaT's Avatar
I like to get the no-meth AFR's under boost (~8#) at about 12-12.2:1. Then tune the meth to get you to a minimum of 11.2 at WOT and your 8#. That's a pretty safe tune. Best case would pull some timing if the meth ran dry, and turn on an idiot light.
You numbers seem plausible, but maybe the nozzle is a bit big for that level boost.
Jim
Old 05-11-2009, 07:43 PM
mike13's Avatar
The way I have it set up now is if I run 6lbs boost my afr's are right in there without meth, if I run 8lbs and have the meth on at 500cc/m my numbers are 11.2-11.5. My controller doesn't spray until it see's 6lb's. It's also progressive.
Old 05-12-2009, 01:09 AM
Im flowing though a 15lb and 10lb nozzles at 100 psi and my system runs to 220 psi when on full tilt.
Old 05-12-2009, 10:07 AM
allthrotle's Avatar
My afr's with meth are right at 11.0
Old 05-12-2009, 10:50 AM
mike13's Avatar
Do you know what your afr is without the meth?
Old 05-12-2009, 11:01 AM
allthrotle's Avatar
Mid 12's
Quick Reply: Meth and AFR question
