Switching turbo turbine
Here is my turboSpecs:
T70 Wet Floating Bearings Turbocharger!!
Compressor Specs:
4" Compressor Inlet
2.077" or 52.77mm Inducer
3.000" or 76.20mm Major
2.5" Compressor Outlet
Compressor .70 A.R.
Compressor 75 Trim
6 Blade Propeller Type
M14 Compressor Housing
Turbine Specs:
T4 Type Turbine
T3 4 Bolt Flange
58.18mm Exducer
Turbine .84 A.R.
Turbine 60 Trim
2.900" or 73.66mm Major
T3 Twin Entry Turbine Housing
I want to know the effects of switching the Turbine to a smaller one -
an .63 A.R. as I have one. Faster or Slower spooling? More or less power in Low or higher rpm range? Will it lower or raise my air flow volume?
Compressor Specs:
4" Compressor Inlet
Compressor .70 A.R.
Compressor 75 Trim
Turbine Specs:
T4 Type Turbine
T3 4 Bolt Flange
58.18mm Exducer
Turbine .84 A.R.
Turbine 60 Trim
Compressor Specs:
4" Compressor Inlet
Compressor .70 A.R.
Compressor 75 Trim
Turbine Specs:
T4 Type Turbine
T3 4 Bolt Flange
58.18mm Exducer
Turbine .84 A.R.
Turbine 60 Trim
Compressor Specs:
4" Compressor Inlet
Compressor .70 A.R.
Compressor 75 Trim
Turbine Specs:
T4 Type Turbine
T3 4 Bolt Flange
58.18mm Exducer
Turbine .84 A.R.
Turbine 60 Trim
oh ****, i didnt even see that its a t3/t4, you should really have atleast a t4 all the way for this project, that t3 hotside is for little motors with less exhaust, hence why the eclipse guys use them on a t4 compressor, so they can move big air with small motor.
