stall?
Old 05-12-2009, 01:23 AM
TravisMcGill2000's Avatar
Default stall?
hey guys im running a tci street fighter convertor. its a 10in 3200 stall. if i went with a yank or a circle d convertor how much time do yall think i will pick up. the tci pulls high 1.6 60fts on motor but seems to fall off up top. i would like a new convertor but if im not going to pick up much in 1/4 times then i will spend the $ on somthing else.. thanks guys
Old 05-12-2009, 07:01 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
You might want to give me a call and let me know what your combo is and let me see if I can help.
Greg
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 05-12-2009, 11:39 AM
01ssreda4's Avatar
high 1.6Xs sound pretty good to me with only bolt ons.
Old 05-12-2009, 12:16 PM
Circle-D's Avatar
1.6's are pretty good, but I think a little higher flash will net better 60's and ET. The TCI clutch is a little weak and you would also be stepping up to a billet setup, which might save the trans. I am thinking a 3600-3800 stall from what I have heard, but give me a call and I can get more specific.
713-895-8834
Chris
Old 05-12-2009, 04:46 PM
the 1.6s 60ft are ok its the slip up top. thanks i will yall some calls
