let me see your air intake setups
Quite a bit of engineering went into this intake. If anyone has seen how close a C1 Vette hood is to the radiator, then you know what I had to do to make the intake go over it. First, I had to lower the core support by adding 1 ½ inches to the bottom and put the radiator on an angle. Then I bought a used Z06 cold air intake and cut it into 3 sections, flipped the part that attaches to the throttle body, so it angled upwards and attached it back to the main body of the intake. Then I made the 90 degree turn and added about 5” to the part that houses the filter. Add fiberglass mat and resin and body filler, and then spray with wrinkle paint. I still need to take care of some odds and ends, before its finished.
