LT1-LT4 Modifications - Need some more opinions...
candyblueta
05-12-2009, 05:21 PM
will this work with true duals w/ a Cross over "H-pipe" right uner the driveshaft??? the cross over is pretty much at the tail section of the transmission...
http://cgi.ebay.com/ebaymotors/93-02-Camaro-F-Body-Firebird-Adj-Torque-Arm-Long-Tubes_W0QQitemZ120411412850QQcmdZViewItemQQptZMoto rs_Car_Truck_Parts_Accessories?hash=item1c09145972&_trksid=p4506.c0.m245&_trkparms=65%3A16%7C39%3A1%7C240%3A1318
ss.slp.ls1
05-12-2009, 05:25 PM
You might have to get some custom exhaust work done. Simple answer is you won't know for sure until you try to bolt it on.
candyblueta
05-12-2009, 05:31 PM
lol!! i knew that was gonna be said
ss.slp.ls1
05-12-2009, 05:34 PM
You should have expected it, no one knows the location and dimensions of your current exhaust set up, therefore no one can tell you if it will fit, you have to try it and see.
candyblueta
05-12-2009, 05:37 PM
wow just realized someone made this exact post...
ss.slp.ls1
05-12-2009, 05:39 PM
LOL, yeah, but his question has a x-pipe, which you should consider installing if you have to rearrange your exhaust.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
