Drag Racing Tech
Finally our new Ballast pics!!
Old 05-12-2009, 09:46 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Default Finally our new Ballast pics!!
We have searched forever trying to find a decent ballast set up for the F-bodys, but no luck prior to this point.
I saw a homemade ballast setup a fellow Mustang bracket racer had and could not help but apply it to the F-body format.
Here are the pics of out new ballast set up. We run a lot of index races that require weight addition in a safe manner. I had a buddy fab up this system and it is very user friendly.
I'm loving this set up myself. It's easy to adjust weight and is NHRA legal.
Here are some pics for ya:
Old 05-12-2009, 09:53 PM
TXCAMSS's Avatar
Standard weights are available at local garage sales. I'm thinking one ballast might be sufficient for most applications, but 2 allows the option of keeping the weight secure and low in the rear hatch.
I've always thrown weight in the rear unsecured and I got lucky. but in the event of an accident, it can be fatal. I don't care to risk that anymore.
I just had to share.
Old 05-12-2009, 09:56 PM
01FbTaWs6's Avatar
funny thing is, i was just thinking about doing this the other day, but was thinking of making something to hide under the rear bumper, like in place of the rear bumper support or something. Similar idea though, but this is much simpler to add/remove weight.
Old 05-13-2009, 06:11 AM
LS1Tech Sponsor
MADMAN's Avatar
Damn James looks nice!! But you already have a problem keeping the front end down.
__________________
www.madmanandcoracing.com
225-343-9029
Old 05-13-2009, 10:06 AM
1SlowFormula's Avatar
so are they going to be bolted down or welded in? I assumed bolted by the looks of that plate, but those bolt holes look a little small to be legal. Isn't the rule at least (2) 1/2" bolts per 100# or (1) 3/8 bolt per 5#, bolted to the "Frame"?
Old 05-13-2009, 11:25 AM
TXCAMSS's Avatar
LOL. Ain't that the truth. I have you to help me in that department, so expect a few calls
I am planning on bolting them in and haven't decided whether to mount both or just one. I rarely use over 100#s of weight. I adjust the shift points to get close and then add weight from there. I'll be opening up the holes or adding more as needed. There will be 3" wide 3/16 steel strap on the underside as a backing support on mine.
Old 05-13-2009, 11:53 AM
dlove's Avatar
what front to rear weight is the car?
Old 05-13-2009, 11:55 AM
Dave J's Avatar
I was thinking of doing that also but I cant figure out where to put the battery box
where are you guys putting it?
Old 05-13-2009, 12:18 PM
TXCAMSS's Avatar
Our battery box is in the right rear pocket. Here's a pic.
I am embarrassed to say, I have no idea what my front to rear weight ratio is. We run an Iron block 408 and also an aluminum block 445 so that will skew the numbers depending on which one I'm running anyway.
Quick Reply: Finally our new Ballast pics!!
