question
Old 05-12-2009, 11:57 PM
allenwesley's Avatar
Default question
Do I need a window switch if I have an a4 and why?
Old 05-13-2009, 08:43 AM
Mike@HSW's Avatar
You don't need one but it can help. If the trans shifts while you are spraying there is obviously more stress on it. If you have a window switch that shuts of a few hundre RPM before the shift point, it could prolong the life of your trans a bit. So basically, if you are on a stock tranny it wouldnt be a bad idea.
Also, pieces like our microedge controller do a lot more then just function as a window switch. So, you are getting quite a few features along with it.
Old 05-13-2009, 11:53 AM
Chris@NitroDaves
Guest
Posts: n/a
What he said and also if you hit the rev limiter on nitrous it could cause some problems as well.
IMO a window switch is a must.
We offer several different models of switchs
http://www.nitrousoutlet.com/catalog...del=86&dept=11
-Chris
Old 05-13-2009, 02:23 PM
Caribe's Avatar
I run the microedge window switch with my A4. There has been times where I have lost traction and the car hit the rev limiter. Do not want to do that when you are spraying. Like Mike@hsw said, the microedge has a lot of features.
Old 05-13-2009, 02:54 PM
ok thank yall im deff gonna get one before i spray, i also will have to get some new sark plugs... thanks for the help
