Air Intake Tubing Size/Fitment
I measured all of the OD's tonight. The LS6 TB is 3-7/8" OD, the TB side of the MAF is 3-11/16" OD and the MAF screen side is 3-13/16". I am going to get a 4" ID to 3-1/2" ID rubber reducing elbow - will I be able to force the MAF onto the rubber? Is there enough stretch to do that?
What about coming off the other side - 3-1/2" ID tubing vs 3-13/16" on the MAF is quite a mis-match. What have others done? -Bob
T,
Got some silicon tubing parts in today - the 4" to 3.5" 90 deg reducer is too sloppy for the TB. I couldn't find a 3.75 to 3.5 reducing elbow. So I'm going to cut a small piece of the 3.75" straight tube as a spacer (about 3/4" wide) - how are you guys cutting this stuff to get a straight cut?
