Burned up my Clutch....
I took my firebird out for a little spin yesterday and ON THE WAY HOME I though it would be a good idea to get on it a little. I stood on it from about 5mph and then... Well the car didnt really do anything, other than make a lot of noise and I could smell the clutch burning....
Stock gm clutch with about 45k on it according to the guy I bought it from (good friend of the family).
I have only had the Firebird out of the shop for about two weeks now... Never really felt anything in the clutch to give me a heads up it was going to go out... What are the stock GM clutches rated for, as far as horse power?
Anywho... I'm thinking SPEC Stage 3 now...
Any thoughts?
Any thoughts?
Internet Mechanic
Any thoughts?
Any thoughts?
ROFL.
I wonder if the clutch was from a 2000 and back or a LS6 '02 and up. I would never buy anything used like a clutch, with exception of maybe a Textralia.
On my heavier then stock weight Trans Am, 2002 which came with a LS6 clutch from factory was fine until I made over 320 rwhp. The peddle would crash after a hard run, no slip, just crash and stick. The slave had a screwed up bleeder so ultimately I put in a new GM slave, and Textralia OZ700 Z-grip and then a little while later, a Tick Perf Master which makes the trans shift solidly now.
When my stocker started to have issues was at 33k. The car got the clutch done at around 36k and now the car has 48k and now makes just under 400 with a cam and pulls wheels.
Stock Clutch = Stock Power.
IF you gut the car for a lower race weight, the rating can go up.
I bought the car and he told me it was a stock gm clutch with 45k on it, the car had 100k on it.
Sorry, I'm retarded...
Give me a call at the shop and we'll go over your clutch needs!
Thanks for the quick reply.
Clutch wear occurs as a result of a number of factors. These include but are not limited to driving style, power out-put, cleanliness or rather presence of contaminents, and properly functioning hydraulics. Without looking at the parts it is darn near impossible to know what the actual cause was...but since you are in the market for a new unit and your already mentioned being interested in our stage 3 give me a call and I will be happy to assist you. My number and email are both listed below. Thanks!
