Help i cant see!
Help i cant see!
i bought a 95 camaro z28 and the thing is my gage lights and dash lights don't work i took the dash a part thinking its a cut wire some where back there and i found nothing i have chaged all the fues what can it be...what do i look for to fix it can some one help i cant see nothing at night the only lights that come on are the check lights in the gage cluster when i turn on the car....can it be the light switch? it turns on the head light but not the dash lights
check for power at the fuse. if there is power there, the switch isn't the problem. the dark green wire that comes out of the switch is for the instrument cluster. check for power on that wire if the fuse doesn't show power. also, the black wire is the ground. check that the ground is secure and showing ground (just hook a test light up backwards). the ground is shared with the cigarette lighter and the courtesy lights also hook up to it.
