Whats everyone doing with O2 sensors after Long Tubes?
1 Post
I got some Hooker headers just installed on my 94. They dont have the O2 sensor holes in them. I plan on running some collector extensions to bullet mufflers to turn downs. Should I just drill and weld a nut onto the collector extension. If I do that what should I do about the wiring for the sensors? Can I buy longer ones or do I just have to cut and rewire them?
Use O2 sensor extensions instead of cutting/crimping.
what size O2 sensor extensions did you guys end up having to go with? I just bought some longtubes and I see they are available in 12 inch and 24 inch extensions, I just want to make sure I buy the right ones!
I used 24". I figured if they are too short I am screwed and need to buy more...if they are too long, you always have zip-ties and those are A LOT cheaper than another extension...if you have excess, tie it off.
Also back to the OP...you need those front 2 O2 sensors so get some bungs and have them installed on your headers. As for the rear 2 O2 sensors, don't tune them out! Get O2 Sims and stick those on there...The computer likes that better than tuning them out...
DO NOT CUT YOUR WIRES do it the neat way get some extensions plug them in and forget about it i purchased 24's and zip tied the slack out of the wires they work great
http://www.lmperformance.com/3112/2.html
ebay
http://cgi.ebay.com/ebaymotors/LT1-G...mZ360133992349
ebay
