moser axle ????
moser axle ????
can a moser axle that was originally sold as a 3 channel axle be converted into a 4 channel axle...im guessing its the same exact axle With out the reluctor rings on both axles! if thats the case then I would assume you can convert the axles to 4 channel just by simply putting the abs rings on...or just eliminating the abs completely with a abs delete kit...
Yes, the only difference is that the end of the axle will need to be machined for the reluctor ring. If you just use the axles as is, you won't have ABS or TCS. The ABS wouldn't work then on the front of the vehicle either, which wouldn't bother me as I don't care for ABS brakes. Bob
