Where does this part go?
Old 05-13-2009, 11:38 PM
race5050's Avatar
Default Where does this part go?
Hi all, I just finished replacing the blown motor on my 2002 Firehawk. Well all went well and the replacement long block started right-up. I had one extra part and I can't remember where it goes. It is some sort of heat shield. It is curved and has two ears with holes for mounting to somewhere. I hope one of you can help me figure out where it goes. I also had two 10mm nuts that were on the motor mount bolts, but I took them off because I didn't see what went bolted to them. Maybe the heat shield?
Please Help!! Thanks a Bunch!
Attached Thumbnails Where does this part go?-sta70138.jpg   Where does this part go?-sta70139.jpg
Old 05-13-2009, 11:52 PM
red02Hawk's Avatar
yeah i believe it mounts to one of the motor mounts
Old 05-14-2009, 12:03 AM
LSX Mechanic
Damian's Avatar
That's the manifold heat shield for the drivers side motor mount. It bolts directly to the mount.
Old 05-14-2009, 12:04 AM
CayenneRedV6's Avatar
Heat shield on driver's side motor mount. I only know that because I just ripped mine off and through it in the trash lol.
Old 05-14-2009, 12:01 PM
01ssreda4's Avatar
exactly correct.
Old 05-14-2009, 12:27 PM
Mumbles's Avatar
The Driver's side Motor Mount to Block Bolts have studs on the heads. The heat sheild you have pictured mounts to the studs on the top two bolts with two 10mm nuts. I think its designed to protect the motor mount bushing from exhaust manifold/header heat.
Old 05-14-2009, 12:46 PM
Ericbigmac83's Avatar
It goes in the trash can
Old 05-14-2009, 04:27 PM
race5050's Avatar
You guys helpful AND FUNNY! Well at least I know it isn't shielding a gas line or anything that might blow-up! LOL! Now I just have to see if I mounted the two stud bolts to the drivers side or passengers. If I chose the drivers side, I'll mount up the shield. If not, I guess I'll throw it in the trash. Thanks for help all!!! I'm totally jazzed that the car started right-up, ran great, and only had the heat shield as a left-over part. Time to enjoy the Firehawk again!
Old 05-14-2009, 04:32 PM
andrew69_04's Avatar
Originally Posted by ericbigmac83
it goes in the trash can
x2 lol
Old 05-15-2009, 01:28 AM
Mumbles's Avatar
Why? To save weight?
Old 05-16-2009, 03:30 PM
Hard Core Z28's Avatar
Extra parts, dont need no extra parts
Old 05-16-2009, 06:19 PM
tording99Z28's Avatar
I second the trash can. Thats where mine ended up when I did my motor mounts.
