Video of my Purge/Pics of my nitrous set up let me know what you think
Old 05-14-2009, 04:23 PM
Frostbitten09's Avatar
Default Video of my Purge/Pics of my nitrous set up let me know what you think
Everything was just installed it is still not fully done. I need to loom everything and make it look all nice and so on. But looking for some opinions and thoughts on my set up.
Here is a video of my purge
and here are some pics of my nitrous set up
Old 05-14-2009, 06:03 PM
anthony1's Avatar
i think that came out pretty sick
Old 05-14-2009, 07:55 PM
sprydncamd ta's Avatar
run the purge line under everything and it will look alot nicer instead of running it around your lid
Old 05-14-2009, 09:33 PM
LT1~LS1's Avatar
Also add a T and blow it out both nostrils!
Old 05-15-2009, 10:55 AM
sweetbmxrider's Avatar
thats pretty sweet
Old 05-15-2009, 01:17 PM
01SOMZ28's Avatar
the install looks pretty sloppy.
Old 05-16-2009, 10:27 PM
capt.ld's Avatar
i ran mine out both sides and mounted it all now in the center in front or the hood latch.its fiberclass mine look realy good. ill post pic of it in the morning so you can see what i did.
Old 05-17-2009, 09:50 AM
driftpin's Avatar
I was going to do mine the same way but the way LT1~LS1 described.
Old 05-17-2009, 10:50 AM
2001z's Avatar
I know some people dont car to much but i would run the lines and everything a little better and try to clean everything up. Maybe get some black wire covering and it will hide it some and kinda blend in. I also agree get a t and make it split the nostril.
Old 05-17-2009, 02:23 PM
Robert56's Avatar
Looks good. If you split your line to dual outlets you may want to up size the lines to keep the flow as big. when I added dual out let from one line the the plume was cut in half, just someting to think about.
Robert
Old 05-18-2009, 07:58 PM
capt.ld's Avatar
dam that looks like a wiring nightmare
Old 05-19-2009, 06:47 AM
driftpin's Avatar
It can be done alot cleaner than that. I personally wouldn't have installed the relay in sight but to each his own.
Old 05-19-2009, 09:13 PM
kwiksilverz28's Avatar
Spaghetti?
Old 05-19-2009, 11:16 PM
TS6
TS6's Avatar
No FPSS? Looks like you installed it in 10 minutes.
