air condition clutch bearing
Old 05-14-2009, 05:20 PM
zrater's Avatar
Default air condition clutch bearing
can i pull the bearing out or do i have to have it serviced. thanks
Old 05-20-2009, 03:45 PM
Etpacker1's Avatar
You can pull it out. You have to get a puller from the auto parts store. Make sure it is the correct one. The threads on the Clutch are fine threads and are easy to booger up. You can even do it while the compressor is on the car and not break the hoses off and lose your freon. Jack up the car on the passenger side and point the clutch down ward once the compressor is removed. It takes some pushing and pulling but it will go to a good enough position that you have access to it and can change it out.
