Turbo LS1 Fox nearing completion!
Old 05-14-2009, 11:34 PM
letsrunem's Avatar
Default Turbo LS1 Fox nearing completion!
Forged 347
My turbo kit
8pt cage
twin Walbros
Autometer gauges
Monster Level 5
AJE k member/a-arms, coilovers
8.8" w/ 3.73s
I'm 20yrs old and did this on a budget!
Old 05-15-2009, 09:33 AM
serpentnoir's Avatar
Not enough belt wrap around the crank pulley.
Old 05-16-2009, 07:15 AM
jleews6's Avatar
Turbo setup looks good so far. Are those truck manifolds?
Old 05-17-2009, 02:53 PM
snketr's Avatar
Looks good.
+1 on the manifolds.
Old 05-18-2009, 04:16 PM
letsrunem's Avatar
Yes truck manifolds. I cut off the flange on the driver's side one and lengthened it to clear the alternator
Old 05-18-2009, 04:40 PM
MeanYellowZ's Avatar
Don't take this the wrong way and I know its a little late now, but you would have been 100x better off moving the alternator up, because as mentioned your crank (and water pump) belt wrap is less than optimal. Then the stock manifold would have worked. Welded/ modified cast iron manifolds, no matter how well they are done don't hold up to the heat cycles a turbo engine will provide it with.
Looks great otherwise though, great to see the young guys doing cool stuff.
Old 05-18-2009, 07:32 PM
gnx7's Avatar
What size turbo are you running and injectors?
Old 05-18-2009, 07:36 PM
$O$OE's Avatar
What transmission cross member are you using? and also transmission?
Old 05-19-2009, 02:04 AM
XpEdItIoUs's Avatar
Nice work.
Old 05-19-2009, 02:12 AM
letsrunem's Avatar
I'm going to see how this works, an EWP is in the future anyways.
Turbonetics TC78, 72lbers
T56. I modified the stock mustang crossmember, it was an auto car.
Originally Posted by XpEdItIoUs
Nice work.
Thanks! Took 3 months. I started with a shortblock and a shell!
Old 05-19-2009, 02:18 AM
XpEdItIoUs's Avatar
Anymore pictures of the manifolds for both sides? Are they close to hitting the frame? Will solid motor mounts me required?
Old 05-19-2009, 02:21 AM
letsrunem's Avatar
I could take a few tomorrow. There's plenty of clearance on the passenger side, I had to grind a bit off the driver's side flange. I'm using the AJE K member and the mounts that it came with.
Old 05-19-2009, 12:58 PM
Capown's Avatar
Nice!! Ill starting on my this week, got my AJE K-member in today.
Old 05-19-2009, 01:54 PM
XpEdItIoUs's Avatar
Is there a manual steering rack on it?
Old 05-19-2009, 04:30 PM
$O$OE's Avatar
Can you explain how yo modified it for the T56 and if you can show some pics..Thanks
Old 05-19-2009, 10:12 PM
letsrunem's Avatar
Flaming river FTMFW
Basically cut out the center section and welded in a new piece. This was my first time doing anything this extensive and I'd say that part wasn't too bad. Making the clutch pedal setup was probably the hardest part of the whole deal.
Old 05-19-2009, 10:13 PM
letsrunem's Avatar
It's ready to fire up now as soon as my tuner is free (Need a speed density tune)
Old 05-20-2009, 09:43 PM
$O$OE's Avatar
When others run a T56 in a coupe and they use "turbo coupe pedals" what exactly do they mean by those pedals? I know they dont mean the SVO pedals..?????? Fill me in on this thanks...
Old 05-20-2009, 11:20 PM
moge11's Avatar
Those would be the pedals from a "Turbo Coupe".....Thunderbird Turbo Coupe! 4-cylinder turbo witha T5. Im guessing they probably had a hydraulic clutch....
Old 05-20-2009, 11:36 PM
letsrunem's Avatar
I couldn't find any at the time so I modified a set of 5 spd Stang ones. A little more involved.
Quick Reply: Turbo LS1 Fox nearing completion!
