Need help on strange noise ASAP *vid included*
cant exactly locate the noise, wherever you go to listen is where you hear it at. sounds like a hollow really loud screetching sound. i'll let you listen and maybe you guys can guess.
had a friend of mine with a c4 that said his opti did this in his vette. but not sure.
http://www.youtube.com/watch?v=_Kut0ohMy8E
and its stuck at buddys house, so as soon as i can figure out the problem i'll be able to get it out of his driveway.
Does it run OK? Can't really hear the motor but it seems like it's running rough judging by how much it's shaking. Is the oil pressure good? Do all the pulleys appear to be spinning normally? Try pulling the belt off and start it briefly just to see if it still does it.
i have an m6, and its running rough becuase i just put new lifters and pushrods in the car and tried adjusting the rockers but couldnt hear over that awesome sqeakin noise.
Here's a few things to try, take the valve covers off check everything out. Hell it may be hitting the valve cover to much lift? Spray some lubricant on the belts an pulleys. Even though it didn't sound like an exhaust leak check the bolts holding ur headers/manifolds on? Check the spark plugs out to, any trouble codes?
no codes, that vid is also with the valve covers off.
had someone hear it over the phone and said could be crank bearing. if thats the case than a h/c 355 with full bmr suspension and a 12 bolt will be going into the car.
that or go buy an ls1 car?
