Graphite or MLS Head Gasket
Old 05-15-2009, 07:49 AM
corvet786c's Avatar
Default Graphite or MLS Head Gasket
I will be doin a head change. I ve searched and came up with diffrent GM Part Numbers 12498543 for 97-01 LS1 and 12498544 for 02-04 LS1. I have 241 casting stock heads now. Can I still use GM MLS head gaskets or do I have to use the Grahite ones??
I want to use the AFR 205 heads. I just dont want any leaks. I heard of leaks in the past but dont remember which gasket caused it?? Anyone know??
Old 05-15-2009, 07:58 AM
conan's Avatar
The GM mls are a very good gasket, and they are more forgiving than the cometic mls gaskets.
Old 05-15-2009, 08:26 AM
corvet786c's Avatar
I understand what u are saying and agree, but can I still use MLS Gasket with out any leaks with AFR Heads. There was a problem in the past I dont remember what heads, I think the 1998 heads. Someone help.
Old 05-15-2009, 09:12 AM
LSX Mechanic
Damian's Avatar
Either gasket will work. The MLS gaskets are a LOT easier to clean off if you ever have to remove the head again so I would go with those. I also think the graphite is a little thinner when crushed, but I can't remember. Been a long time since I used a set.
Old 05-15-2009, 11:07 AM
Aaron1017's Avatar
Whoever thought graphite gaskets were a good idea needs to be shot! I spent FOREVER and a day cleaning that crap off my block when installing new heads.
Old 05-15-2009, 11:13 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
thanks for the order chris
MLS it is!
Old 05-15-2009, 12:39 PM
corvet786c's Avatar
Your welcome
Old 05-16-2009, 10:58 AM
Pharcyde50's Avatar
MLS all the way
Old 05-16-2009, 03:07 PM
99blancoSS's Avatar
Mls
Old 08-10-2015, 09:05 PM
Vegas02ta's Avatar
Mls all day
Quick Reply: Graphite or MLS Head Gasket
