LT1 WATER PUMP BOLT PATTERn
Old 05-15-2009, 01:31 PM
F3RR3T's Avatar
Default LT1 WATER PUMP BOLT PATTERn
Is the LT1 water pump bolt pattern the same as a regular SBC.
im switching to a electric water pump. and if possible im going to use one for a SBC to get rid of the ugly stock water pump
Old 05-15-2009, 01:34 PM
ss.slp.ls1's Avatar
http://shbox.com/ci/water_pump.jpg
You'd have to find a different water pump housing that will clear the timing cover and opti. Haven't seen anything besides the stock unit used. I don't see how much better looking one water pump is to another anyways...
Old 05-15-2009, 01:41 PM
F3RR3T's Avatar
this is what i was going to use http://store.summitracing.com/partde...5&autoview=sku
if not ill just have my stock one powdercoated
Old 05-15-2009, 01:50 PM
ulakovic22's Avatar
SBC pumps won't work on LTx blocks because of reverse flow cooling. If you look at the block it has two holes for feed/return versus only having the feed holes on SBC/BBC blocks. This is also how the LTx can run a dry manifold versus a wet style the SBC/BBC run. You can get creative with maybe making an adapter if you REALLY want to.
Old 05-15-2009, 09:14 PM
shbox's Avatar
An SBC pump and LT1 pump are not compatible.
Quick Reply: LT1 WATER PUMP BOLT PATTERn
