wrong radiator
Old 05-15-2009, 04:01 PM
goinfast's Avatar
Default wrong radiator
hey guys, my radiator cracked on the plastic end tanks. so i ordered a new one from carquest. when i got my new rad it was missing the fitting on the bottom left for the oil cooler and has two extra holes on the right tank. this was the only rad listed for my car. does anyone know where i can get the right rad for my car in ontario canada or have a solution too make this rad work.
Attached Thumbnails wrong radiator-camaro-rad.jpg   wrong radiator-camaro-rad2.jpg
Old 05-15-2009, 04:45 PM
ss.slp.ls1's Avatar
The two fittings on the passenger side are for the automatic trans lines. You don't have to do anything with them. The missing oil cooler port is not a big deal if you plan on deleting your oil cooler. Otherwise order this:
http://store.summitracing.com/partde...5&autoview=sku
OEM part # is 52466004 and you can get it from GMpartsdirect for 206. They don't have any pictures so I don't know if it comes with the oil cooler port.
Old 05-15-2009, 05:15 PM
goinfast's Avatar
ya i said screw it and took off the oil cooler and plugged the water pump
Old 05-15-2009, 05:29 PM
moderate Z28's Avatar
^I bet it looks alot cleaner under the hood too!
Quick Reply: wrong radiator
