View Poll Results: Which pistons are you running
stock
12
10.81%
diamond
32
28.83%
mahle
15
13.51%
JE
12
10.81%
weisco
28
25.23%
ross
6
5.41%
other
6
5.41%
Voters: 111. You may not vote on this poll
Which pistons are you running?
Old 05-16-2009, 01:00 AM
extremetoy's Avatar
Default Which pistons are you running?
all these threads about pistons breaking and im always hearing everyones opinion on which piston is better than another... so id thought id start a poll to see what people are running..
Old 05-16-2009, 08:13 AM
conan's Avatar
Mahle flat tops with -4cc relief.
Old 05-16-2009, 01:49 PM
Smearin's Avatar
I hear good things about Diamonds
Old 05-16-2009, 02:25 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I have two sets of Wisecos and one set of Diamonds. I like a few things about the Wisecos a little more shelf wise. There's a thread about this in the GENIV internal engine section where everyone talks about what they have.
Old 05-16-2009, 02:32 PM
BlkHwk's Avatar
I have ceramic coated diamond blower pistons. Can't say about the others.
Old 05-16-2009, 05:57 PM
extremetoy's Avatar
i didnt know there was one over there but everyone here has some kind of forced induction
btw im running mahle flat top with a -4cc valve reliefs... not looking for advice, just seeing what everyones running
Old 05-16-2009, 06:51 PM
elias_799's Avatar
weisco pistons here, but my motor is not running yet
Old 05-16-2009, 08:08 PM
OWN3D BY MY PROF!
Other piston thread:
https://ls1tech.com/forums/generatio...o-pistons.html
It's also spelled Wiseco.
Old 05-17-2009, 06:40 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Thermal coated Diamonds here.
Old 05-17-2009, 10:06 AM
valiant65's Avatar
Have anyone bent their stock wiseco pins in FI application? I see that the wrist pins are the same (S643 0.927x2.250) for every list piston. Is there possibility to upgrade the pin?
Old 05-17-2009, 11:48 AM
digitalsolo's Avatar
Stock pistons here, 8 lbs currently going to 15. 9.1:1 compression, 5.3L, intercooled + meth.
Old 05-17-2009, 12:24 PM
'Trust''s Avatar
Custom Diamonds here, rated to 1000hp, no issues thus far. 18psi, 20* timing and 93+Meth.
Old 05-17-2009, 03:02 PM
cablebandit's Avatar
wiseco had me upgrade to their tool steel pins for 1000hp. Now i just need to make that 1000
Old 05-17-2009, 04:18 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Yea, there are a couple piston threads out there in the internal engine sections, but I think the FI section needs one. Heres another piston poll thread: https://ls1tech.com/forums/generatio...t-pistons.html
I ran flat top (-4cc valve reliefs) mahles in my LS6 with up to 16psi in the 700+ rwhp range and up to 20* of timing with no problems. The 370 im putting together right now will have wisecos tho since i dont feel comfortable with the mahle dished pistons. I've also heard good things about diamond pistons as well, but no experience with them.
Old 05-17-2009, 05:33 PM
Fireball's Avatar
coated JE
Old 05-17-2009, 06:11 PM
GrahamHill's Avatar
Diamond 11503 here, although completely unproven. Maybe one day in the next year lol
Old 05-18-2009, 11:47 AM
FWIW I've seen Diamonds take insane amounts of punishment in the 3800 world with roots blowers (aka portable heaters). If their LSx stuff is on par with their 3800/3.8L stuff, it's good chit.
Old 05-18-2009, 12:41 PM
Photochop's Avatar
Same here. Haven't heard about these having the same catastrophic failures as the dished ones have had here lately...
Old 05-18-2009, 04:10 PM
TNTramair's Avatar
i run Diamonds...so far so good.
Old 05-18-2009, 06:43 PM
The Beast's Avatar
Diamond -15cc ceramic coated
Quick Reply: Which pistons are you running?
