Running an 8.4 in the 1/8th
Old 05-16-2009, 01:44 AM
djlackore's Avatar
Default Running an 8.4 in the 1/8th
I have a lid, ls6 intake, long tubes, a cut out and a dyno tune. Does this time sound about right? I am on street tires launching at about 1500k .60ft is 2.0xx and mph is 86.
Old 05-16-2009, 02:06 AM
Quick Sh0t xMLx's Avatar
It's not bad, basically a 13 flat. Looked at one of your previous threads and saw it was an automatic, 2.73s or 3.23s? Stock stall, street tires, not much more you can do.
Old 05-16-2009, 02:13 AM
djlackore's Avatar
yeah it has 3.23s and stock stall.do you think in the 1?4 i could possibly hit 12.9xx?
Old 05-16-2009, 02:25 AM
You have more than enough power to run in the 12s. That run could have well been a 12.9x but no way to know for sure. Better 60', better air, anything like that could easily push you into a definite 12 second zone. If you happened to get DRs+stall your times would drop dramatically.
Old 05-16-2009, 03:09 AM
BlueBird346's Avatar
Yea. I ran two 12.9s, which were 8.4 in the 1/8th. With the same mods as you minus the tune.
Old 05-16-2009, 10:27 AM
Vogos97c5's Avatar
Your stock stall is killing you. I have the same problem, even with sticky tires I'm only cutting 2.0x 60' times. My car bogs with the M/T's on there, just not enough rpm off the line to get the car moving. Getting a stall would be your best bet, that will make a night and day difference.
Old 05-16-2009, 11:12 AM
N2RACINGLS1's's Avatar
Well our 02 WS6 which is a 6 spd. runs between 8.25 to 8.40's which I think runs pretty good. The 8.25 1/8 mile run was a 12.75. The 60 foot times are around high 1.80's.
The only mods on the car is a lid and K&N filter with Nitto's DR's with stock exhaust.
N2
Old 05-16-2009, 04:26 PM
Chuyz69's Avatar
I have a 94 z28 with pacesetter LT, ory, slp loudmouth, k&n intake kit, built 4l60e with a 2500 stall also with 3.23's and M/T drag radials
It was at my local 1/8 mile track and I managed to cut a 1.81 60' and a 8.42 at 83mph oh and not to mention it was about 100+ degrees can you guys let me know if that is a decent time thnx
Old 05-17-2009, 09:25 PM
jsteadman2985's Avatar
I ran 8.84 @ 80.87 in 1/8th and im stock with k&n intake, lt's, xpipe with dumps, and stock 2.73's. ran 8.5x with m/t et streets
Old 05-17-2009, 09:39 PM
philsblwnz28's Avatar
I am guessing my car is a freak for some reason. I am running consistently 12.9@108 all day long w/ a 2.0 60ft. All I have is P&P stock TB, gutted cats, egr and air delete, 3.23 gears, A4, and a tune....That is on street tires.....So I have no idea what going on with mine...
