car not starting help...
Hey guys, finally got my car back together in the process of trying to get it to start, here's what i've done:
1) charged up battery - checked all grounds - all fine.
2) clutch in - car in neutral try to start, nothing... (no click, no noise, simply nothing.
3) check fuses for ignition and in engine bay, no blown fuses
4) short starter w/ screwdriver, car turns over.
5) turned lights on, try to start, nothing, no drop in voltage at all.
6) Left key in on position checked for voltage at purple wire, nothing.
7) put a voltage probe on the purple wire in the ecm harness inside car, tried to crank no voltage.
8) starting to think maybe VATS
9) fire up laptop and try to connect LT1Edit to wipe VATS out. F&$#$ can't connect, keeps trying to connect but fails. COM port is fine and matches the adapter.
10 ) thinking maybe my usb to serial cable at fault, so I try connecting with Autotap and autotap connects fine.
Any thoughts what else I can try?
- Anyone tell me what the right port settings are for LT1 Edit com? mine are 9600/8/none/1/none
was thinking of jumping the VATS relay, but it's in the dash and hard to get to. Want to make sure i've thought this through before i get further.
update: I've gotten lt1 edit to connect now, switched around and tried different cables that did the trick.
I disabled VATS and reflashed the pcm. everything was good from that perspective. Went to try starting again and still no luck, same situation. Any thoughts anyone? i'm stumped on this one.
solved
Well since I didn't have power to the purple wire, I chased it back to the relay. I pulled the relay down and took it off. I jumped the yellow and purple wires through the harness and ...bam!!! fired right up through open headers two years in the making, finally hearing it fire up feels good!
