VATS resistor bypass?
I have tried to bypass the VATS system with a resistor that matched my key....The key measured 1.1 ohm....All I could find was a 1 ohm resistor 1/4 watt..well It didn't work. I know I need to find a 1.1 ohm but do I need a 1/4 watt or a 1/2 watt or does it matter?
wrencher
I have never seen a pass-key with that low a resistance value.
Did you check on the pellet of the key on each contact?
It should have a resistance value in the thousands or K.
Maybe you got a reading of 1.1 k?
That is 1100 ohms.
If you got 1.1 ohm that is basicly no resistance.
That is 1100 ohms.
wrencher
Depending on the meter there prolly is 3 setting if it doesnt auto range?
Is this an anolag or digital?
You want to measure in K or thousands
There are settings for strait ohms & fo M as in mega or 100k = 1m ohm.
So if you read it in K scale it is 1100 ohms.
What watt rating resistors should I be using? I bought 1/2 watt rated on a guess. So what I gather is the orange sheath with the white wires in it that goes to the connector, I'm planning to disconnect the orange sheathed white wires and in it's place put a 10k ohm 1/2 watt resistor looped each end to the connector. I measured the key at 11k ohm, but I also measured the 10kR at 11k-ohm so pretty sure my meter is cheap...
Anyway what my real question is, is what watt rating should my resistor be? I'm not electrical engineer, and I didn't even stay at a holiday inn express last night, but I was putting some simple math to it and nothing seemed right. Let's say 12v and 1 amp, power would be P=I*E = 12W. My R is 1/2w rated. So hoping the V is way under 12 in this circuit and/or the amperage is way under 1A. Well anyway if someone in the know could reassure me that my 1/2w resistor won't burn down my car it would be much appreciated.
Ok, but I didn't buy 1/8, I bought 1/2, will that be ok? By my meter, both the key and the R measured the same 11k so that should be the right R value. I am wondering though how close the value has to be to be right, but I think this one will do.
that was my thinking. So here's how it went. Wanted to use a connector, but couldn't find a suitable substitute, so I cut the wires :cringe:. Did some amateur soldering...plugged in the connector with the resistor...turned the key...nothing!!! doh!!! At that point I was thinking, damn forgot to check the circuit with the key in. So I put the key in and tested the loop in the column at the cut...same resistance doh! Cut my wires for nothing, the vats was working fine all along . So I was like wtf, jacked the car up, looked at the starter, grabbed a mallet and whacked the starter a few times and wiggles some wires down there...voila, the car started up lol. So all that vats crap which I never thought it was anyway, and it appears to be my starter. On the bright side, I'm that much more familiar with my car. On the down side, I disabled my vats. But that's ok because now I can get a second key for not 50 bucks or whatever it is. Any advice on straightening out my starter?
Edit: BTW, I'm still not absolutely sure it was the starter, because years ago I thought it was the starter relay and it turned out not being it. Hoping the starter will cure it
