General guidelines for spray A/F and timing?
Old 05-16-2009, 03:23 PM
pHEnomIC's Avatar
Default General guidelines for spray A/F and timing?
Can anyone tell me what is the recommended a/f ratio and timing are for different amounts of nitrous?
I have a torquer v3 w/ 150 wet shot.
How much should i pull and fuel at for the following levels:
75
100
125
150
I realize there is a lot of factors, but where are good starting points?
Old 05-16-2009, 03:38 PM
Fondle's Avatar
2* timing for every 50hp
Old 05-16-2009, 11:28 PM
LLC
LLC's Avatar
A/F= 12.0-12.8 will be on the conservative side.
Make that 4* for 50.
Old 05-16-2009, 11:38 PM
robsquikz28's Avatar
2* per every 50 shot will be just fine and you really shouldnt worry to much about the afr if you can just read the plugs
