Need help identifying injectors?
Old 05-16-2009, 06:42 PM
summitproducts's Avatar
Default Need help identifying injectors?
I am looking at selling some injectors i have. i was told they are a 48lb injector but i want to make sure. also what should i ask for these. part # is 24508208 these are i believe a gm injector but i may be wrong. these are off white or white in color. thanks for any help that can be offered.
Old 05-16-2009, 08:19 PM
FICINJECTORS's Avatar
see if there is another number on the injector starting with 0280------
Old 05-16-2009, 09:23 PM
Old 05-17-2009, 10:46 AM
0280155811
that is a Bosch 3 36lb rated at 3bar, they came standard on the late model pontiacs with the turbos
Old 05-17-2009, 01:51 PM
arent the newer ls1 cars rated at a 4 bar if so is that the same rate or wouldnt it be higher?
Old 05-17-2009, 04:46 PM
I wanted you to know what the injector was first.. In an ls1 they will flow a tad over 42..
Old 05-17-2009, 05:41 PM
ok. thanks for the info its gonna help me out.
Old 09-02-2013, 01:00 AM
Blk_Ws6's Avatar
So I have the same injector , Do you tune for a 36lb on a ls1 or 42lb ?
Old 09-02-2013, 09:16 PM
The ifr should be 42 at o Kpa since you have a 4 bar fuel system using 58 psi base pressure
Quick Reply: Need help identifying injectors?
