how can i know if the cam response nitrous well ?
Old 05-16-2009, 11:55 PM
PONTIAC SLP's Avatar
Default how can i know if the cam response nitrous well ?
hi like the title says , how can i know if the cam is good for nitrous or not ? from duration / lift or LSA ?
Old 05-17-2009, 04:03 AM
transamfreak01's Avatar
It dpends a lot on the shot you run. If your running 175 and under ur fine but once you go bigger than that then the cam will come into play
Old 05-17-2009, 06:26 AM
DaveX's Avatar
responds to
Old 05-17-2009, 08:01 AM
LS1Formulation's Avatar
If you're running a big shot, say 250HP or larger, you'd want a cam with a bit less overlap and about 6-10 degrees more timing on the exhaust than the intake. For instance, 224/232@.050. When you run a large shot of nitrous you produce a much larger volume of exhaust that needs additional exhaust timing to completely evacuate the cylinder. The purpose for having slightly less overlap is so you you don't just send your nitrous out with the exhaust during scavenging.
Old 05-17-2009, 10:31 AM
thanks guys for the help , how about this cam 244/250 615/615 110LSA ? my buddy wanna spray 150HP it's good ?
Old 05-17-2009, 05:44 PM
how about this cam 244/250 .615/615 110 for 150HP ? my buddy's camaro 98 M6 mods patriot LS6 heads 59cc stage 2 , diamond pistons -2 , 6.125 rods
Old 05-17-2009, 08:31 PM
quick346's Avatar
Default cam
I am running a 243/251 .624/.624 lsl 110+4 and plan on putting 200 on it but have not had it out yet.
I do have it running and i will say it has one hell of a idle i would not dd this cam. soon as the back half is finished i will take it to the track and post some results
Old 05-17-2009, 08:33 PM
what is your mods with that cam ?
Old 05-17-2009, 11:10 PM
yeah ull be fine on a 150shot no problem
Old 05-18-2009, 07:42 PM
quick346's Avatar
59cc afr's,fast92,k&n cai,UMI tb,nitro daves plate,.040 cometics,lts, 5000 stalh,upgraded fuel system (lpe pump,boost a pump,injecters) slp oil pump and t chain and gears,arp rod bolts and some deep *** flycuts in the pistons.
I have ran a 150 shot on the following cams also in the last 2 years all were xer lobe's except the first one was a xr lobed cam and the newest is the lsl lbes. all 3 until now were ran with a 3500 stalh
comp xr 281 228/230 .573/.578 112+2 great first cam for me
comp xer 281 232/234 .595/.598 112+2 best overall cam i have ran
comp xer 238/242 .605/.609 112 on the bottle great cam but off this cam needed alot of rpm to not fall off on the 1-2 with a a-4 in a heavy gto.
once i raised the shift points to 71-7200 ( no n2o) it woke up pretty good and then a 68-6900 2-3 and 3-4
