Any ideas on what is wrong with my car
I was working on the clutch, was getting hard to shift. blead the slave. Cranked the car, and released the clutch (thought it was in netural, it was in first) the car lounged violently and back fired, then died. Cranked it back up, popped the hood and noticed a silcone coupling collapsing , died when I gave it gas. Took off the air filter and noticed it had vacume from the intake from hell, runs rough a few secounds and dies. Dies instantly if given any gas. Will crank pretty easy, hooked my diablo predator tuner up didn't throw any new codes. Had 3 from before high air flow (have a turbo), alt terminal low ( relocated alt had to splice wire), egr low ( removed from car to allow alt to be moved there). I do not know where to start , I'm at a lost, any suggestions ?
