Can't get into gear with tick
Broke transmission six months ago finally got it rebuilt. I installed the tranny today with car off I can go in all gears. I first started car and drove out of shop fine after about 4 miles I couldn't get it to go in gear I would have to keep pressing the clutch pedal In for it to go in gear. I have a brand new tick master I bench bled before going in car. I also have a brand new Gm slave. My clutch is a textralia 0z700 with under 3k miles I'm clueless and frustrated is the line getting hot?
This might be problem but I found the master line resting on header and melted some of the rubber protection I'm waiting for it to cool to see if that's the problem I need to move it
There should be a sheet metal shield where the masterline can be routed.
Also it's possible the hydraulic fluid has been beyond the boiling point.
Might need to be changed out.
