why investing in a degree wheel is a good idea
stumbled across this on Flowtech inductions site. such a simple thing that can have an effect on so much performance.....
“I installed it dot to dot.”
This is one of the most popular comments I hear after less than ideal results are seen when a camshaft installation is completed. Just the mentioning of this sends chills down my spine.
The proper installation of a camshaft and its peripheral valvetrain is one of the most important jobs an installer must do when maximizing the performance of any engine combination. Any short cuts or miscues in this regard, and the overall success of the project, and its ultimate performance, will definitely suffer.
How can something so simple be so problematic?
Let’s start with the basic premise that everyone can have a bad day at work. Who’s to say the crankshaft keyway was machined absolutely “dead on” when the machinist set it up? I mean, even a slight error of a degree or two is no big deal considering the thousands and thousands of engines out in the world. They run, don't they? Maybe it wasn’t even a bad day but something that is machined off the mean number but still within manufacturing tolerances. What's a degree or two among friends?
Now we have the next piece of the tolerance puzzle, the timing set. There are a series of variables that can occur with this component. The relationship of the keyway to the crankshaft sprocket teeth, the location of the cam dowel hole to the cam sprocket teeth and then there’s always the possibility of “both” items being off. Why worry? Well, if each facet is off in the same direction, it is a cumulative error that will change the engine's dynamics. That's why verifying the intake centerline as it relates to top dead center is very important.
When you're installing these two pieces to the engine, who’s to say they are so perfect, there’s no reason to check them?
UNDER PRESSURE MOD
The only caviat to that is you need an adjustable timing gear because if it's off by say 2 degrees, one tooth on the timing gear isn't going to give you that difference. What the difference is with one tooth difference, I don't know, but unless you have adjsutable timing gears, which I thought I saw a vendor selling recently, dot-to-dot is as best as you're going to get.
Would'nt this apply more to custom grind cams? Are the "Off the shelf" cams off to the point where they need to be checked? I know for piece of mind, but has anybody seen a shelf cam wrong? I am not sure, thats why I am asking, dont flame me
the CUSTOM grind cams are the same as the shelf grinds,i mean as in ground on the same machines.just slightly different in most cases by maybe on a tighter lsa,mixed lobes or other minor things but they are ground by the same people,which is probably a majority by comp cams in memphis.
UNDER PRESSURE MOD
Okay, so lets say the cam is off by 1-2 degrees, with the stock timing gears how would you correct that? From what I understood, if you go one tooth in either direction, it would be quite a bit more than the 1-2 degrees that the cam was out.
I'm asking because I'd like to know the answer myself. My tr224 is installed dot-to-dot just like everyone else does. Certainly the next cam that gets installed will go in with an adjustable set of timing gears so that everything is 100% spot on.
Since the cam moves at 1/2 the speed of the crank you can index (the stock set) fairly easily. It just takes more time and wont give exact results. Look at the crank sprocket of a crank keyway adjustable set and you'll see what I mean. Its just hard to wrap your head around.
http://store.summitracing.com/largei...le-55000_w.jpg
