98 Trans Am with Offset T-Tops
Old 05-18-2009, 12:51 PM
Rhin's Avatar
Default 98 Trans Am with Offset T-Tops
My daily driver has offset t-tops. I could be paranoid, but the offset is slowly getting worse. I believe this is the result of a tweaked body and or frame.
Is there a way to fix this? If so, how much would i have to spend to have it professionally done? Would it be better just to retire her to the scrap yard once i strip the engine, wiring, rims, and body panels for one of my shell project cars?
Old 05-18-2009, 12:54 PM
ttranssam's Avatar
need pics...
Old 05-18-2009, 01:43 PM
Rhin's Avatar
Here are some pics...
Attached Thumbnails 98 Trans Am with Offset T-Tops-004.jpg   98 Trans Am with Offset T-Tops-003.jpg   98 Trans Am with Offset T-Tops-002.jpg   98 Trans Am with Offset T-Tops-001.jpg
Old 05-18-2009, 02:51 PM
jdoostil's Avatar
man, that sucks. Hopefully its fixable. It would be a shame to scrap the whole car. Sorry I dont have an answer, but does it leak?
Old 05-18-2009, 03:16 PM
Rhin's Avatar
They leak if the water pressure gets to high. For example wind and rain forces water into the cab. A carwash would drench my interior.
I have a '95 Trans Am (Hardtop) I could put everything into this summer but the 98 holds some sentimental value.
Old 05-18-2009, 03:31 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Bet u do not have SFC's.
Old 05-18-2009, 03:42 PM
Rhin's Avatar
Its completely stock and I do not race it. The dammage happened when I hit a curb after a blowout, about five years ago.
Old 05-18-2009, 03:43 PM
NHRAMAN's Avatar
Exclamation
something is severely twisted for sure.
Old 05-18-2009, 09:20 PM
cvalliere's Avatar
Are your door gaps tighter on one side then the other? I would take it to a body shop that has a lazer measuring system for frame repair.
Old 05-18-2009, 09:59 PM
Lotus289's Avatar
Agreed. It seems that you've really twisted something. Getting it measured at a frame shop is probably the best first step.
And you can't go wrong w/ a good set of 3-pt SFC's. If the car isn't too far twisted those might be enough to straighten it out.
Old 05-19-2009, 05:44 AM
cvalliere's Avatar
That is what I have, love them. They made a world of differance.
Old 05-29-2009, 03:59 PM
Rhin's Avatar
Just got her back from the body shop. The guy says she is straight and that the T-Top seals are fitting correctly. The doors, hood, and hatch all have too good of a fitment for anything to be tweaked; also, there are no signs of stress on the fram anywhere.
Has anyone seen such an offset before?
Old 05-29-2009, 06:05 PM
Lotus289's Avatar
It's a bit hard to tell from the pics, but is your car a factory T-Top? I looks like it is to me, but I'm not 100% sure. If it is, and your certain that the rest of the car is straight, you may want to look into adjusting the T-Top pin guides inside the A and B Pillar covers. Maybe those got shifted. That would definitely account for the offset.
Old 05-29-2009, 07:27 PM
Rhin's Avatar
Factory T-Tops. All Y82 Firebirds (Trans Am Trim Level) from '98 to '02 had t-tops as it was included with the Trans Am package.
Do i need to pull the plastic pin guides out to adjust them, or do i adjust them as they sit?
Old 05-29-2009, 07:35 PM
Lotus289's Avatar
You have to pull the A-Pillar covers only for the fronts. For the rears you have to pull the B-Pillar covers and you may have to pull the headliner (which includes the dome light and I think some seatbelt stuff too). But I've adjusted them with the headliner in using a regular wrench. You may just have to pull the headliner out of the way a bit, just don't break it.
Then there's just 2 bolts per guide that need loosened and you can adjust from there.
