need 383 head gasket
Summit has all the gaskets you could need. Depending on what kind of compression ratio you're looking for will depict what thickness gasket you get. Stock is .049 I believe. The felpro 1074's are .039. Impala gaskets are .028. Alot of guys use the Mr. Gasket 5716's and they are .026. That's what I use to help get the compression ratio up.
