Really confused on what injectors to get
Ok i have a 408 with a 246/254 cam, TFS 235cc heads, ported FAST 90MM intake. I will be throwing on up to a 200 shot of nitrous on either a wet kit or direct port. Ive been told that i need 42's and 60's by 2 different people and Ive been given 2 completely different opinions so Im really confused. What do you guys think would be best for my setup? Im looking for 550rwhp N/A.
Figure 625chp and go to the RC calculator on the sticky here.. 42 at 3 bar is the injector.. Telling him to put a 60 Siemens in IMO is way to big.. It flows 73lb/hr in a LS car and the 42 flows 50lbs. Why over inject an engine, now if you have a procharger than the 60 is the right number because of the increase in the BSFC,,
Rich
Listen to Rich. Him and Jon know injectors. If you over shoot the size it makes tuning more of a pain in the butt. WOT is easy but around town driveability is not as good.
Size them for the engine, if you are putting a wet shot on, it has its own fueling anyways so you don't need the oversized injector for that either.
DO REMEMBER PLEASE... the 255L/hr PUMP maxes out at a 50LB/HR injector... the fuel pump (255) cannot pump more fuel than a 50lb/injector.
SO, that means if you plan to go bigger or more power later, you will DEF want to go ahead and get a 340L/hr pump and pair it with those 42# injectors or even the 50LB injectors , IMO.
Check my fuel and injection sticky let me know if I can help further
