Foam bumper supports???
Just removed the bumper cover and the support is foam..... WTF???? I was hoping to lose 20lbs.... That thing might weigh 3#s...
Will try to upload pictures tomorrow.
I think since you have a T/A your going to need to fab up a new mount or loose the fog lights.
to loose the 20 pounds you have to also remove the steel support bar that the foam is attached to. its 3 15mm nuts on each side at the front frame rails, heres a pic from when i pulled mine out of the cmaro last week.
So this is normal then? Good to know.
