Miata differential upgrade options for LS1..
Besides the 8.8 setup everyone is using, are there some factory options for differentials? Will RX7 or RX8 diffs work? Do they bolt in? I'm just curious what kind of options I might have. I'm probably about to trade my Msutang for a Miata, and a good friend of mine just gave me a pile of LS1 parts, so I obviously have only one choice....SWAP TIME!!!!
I'm running the Getrag stage 1 from Flyin Miata
http://flyinmiata.com/index.php?dept...002%20%208.8S1
using a 3.42 LSD from a 2006 Cadillac CTS
d
d
You might be thinking of an FD diff which came with a torque arm, turbo 2 diffs in the FCs didnt have torque arms
You could use the bolts with a torque arm though prob, as it works similarly
TII aluminum housing + 1988 929 carrier with 3.73 gears + TII diff = direct bolt in factory rear end with limited slip and 3.73 gears.
http://picasaweb.google.com/alaivins...78269943330050
Andrew
Andrew
Andrew
Andrew
Looks like the issue would be that the diff is shorter thus the rear flange will hit the rear subframe.
Andrew
http://www.mazdamotorsports.com/pdfs...Drivetrain.pdf
