Will these 3.73's fit my car? *pics*
Old 05-20-2009, 11:00 PM
black_phoenix's Avatar
Default Will these 3.73's fit my car? *pics*
So a while back when my brother had his 02 z28 camaro A4 he bought some aftermarket gears. Originally he had 3.23's in it. So when the day came to install them, he took it to a mechanic. When he took the rear end apart he said that the gears do not fit.....
Well, about a year later, and these 3.73's are still in my house, unused so im thinking whether or not these would fit my 2002 t/a M6? Unfortunately i cant tell exact dimensions of those gears since im a complete newb when it comes to that but i do have pics:
3.73 gear:
camaro gear 3.23 i think:
Camaro gear on the left, 3.73 on the right:
3.73 gear:
camaro gear:
both of them, camaro gear on the left, 3.73 on the right:
Old 05-20-2009, 11:26 PM
Duffster's Avatar
Uhh... do you have the pinion gear?
If it's the same internal/external diameters and has same bolt hole patterns for the carrier, then yes...
Old 05-21-2009, 12:16 AM
Here are the pics of the pinion gear. I really cant tell the measurements... on the top there is "2,999" written...
Old 05-21-2009, 12:20 AM
Slvr00Bird's Avatar
If your brother had a 3.23 from the factory, then he has a 3 series carrier.. If those won't fit in his, then they are for a 2 series..
If your car has a 3.08 or lower in it from the factory, then that gear (2 series) will work in your rear (also 2 series).
Old 05-21-2009, 12:22 AM
well, my car has stock gearing 6 spd 3.42...
Old 05-21-2009, 12:33 AM
Slvr00Bird's Avatar
Then yours is a 3 series too and they won't fit yours either.. when you go to order new ones, you need to make sure you buy the right series for it..
Old 05-21-2009, 12:45 AM
thanx man, good thing i asked before i went to install them
Old 05-21-2009, 12:48 AM
Slvr00Bird's Avatar
No problem at all man
Old 05-21-2009, 10:41 AM
01ssreda4's Avatar
i agree....
Old 05-21-2009, 02:14 PM
well thanx for the help guys, looks like the issue is resolved...
what do you think this will fit for? Older camaro ?
Old 05-21-2009, 02:43 PM
marors1's Avatar
They should fit any 10 bolt rear that originally had a 3.08 gear ratio or numerically lower. This means that it would have had a 2 series carrier. My auto 1999 came with 2.73 gears, so they would fit on my differential carrier. It is usually easy to tell the difference, the 2 series replacement gears are significantly thicker to take up the difference in offset on the differential carrier.
D
