LCA Bracket question?
Old 05-21-2009, 11:14 AM
Daredevil_TA's Avatar
Default LCA Bracket question?
I have UMI LCA relocation brackets bolted in to my stock 10 bolt- I was wondering if they would bolt in to a moser 12 bolt?
Old 05-21-2009, 11:38 AM
98LS1Kid's Avatar
No most likely not because even on UMI website it says that the bolt in brackets are only good for the stock 10 bolt and the strange rear ends. They have a specific bracket for the Moser rear ends.
Old 05-21-2009, 04:08 PM
UMI Performance's Avatar
Unfortunately like mentioned they won't fit correctly. The Moser rear ends user wider control arm mounts and there shock mounts sit in a different location. We do have a set for the Moser rear ends but they are weld in only.
Hope that helps!
Ryan
Old 05-21-2009, 08:46 PM
so what about a strange 12 bolt?-i just hate the fact of selling those relocation brackets to get a new rear end
Old 05-22-2009, 06:42 AM
Nick, They will bolt onto the Strange rear ends with no problems. I currently run the bolt on set with my Strange S60.
Hope that helps!
Ryan
Old 05-22-2009, 11:57 AM
yes that helps alot, thank you!
