Trans plug?
Old 05-21-2009, 08:56 PM
syclone74's Avatar
Default Trans plug?
Hey guys I am getting a p0740 code and some one said it could be the trans plug? What is the trans plug and where is it.
Old 05-21-2009, 09:00 PM
spaz1's Avatar
It is on the pass side top of the trans. I don't think it is the problem unless it is all corroaded, The issue is with the torque converter clutch ckt.
Old 05-21-2009, 09:03 PM
syclone74's Avatar
What is the Torque converter clutch ckt? Is this the same thing as the tcc seloniod?
Old 05-21-2009, 11:55 PM
spaz1's Avatar
yes it is the tcc ckt. Is everything else working ok? could be the tcc solonoid in the trans. The tcc solonoid comes with the internal harness. The control wire from the pcm to the trans is the tan black wire goes to pin t on the trans and comes from pin 42 connector c2 at pcm. Make sure this wire is ok. The pcm grounds this wire to activate the tcc.The power comes from fuse pin e on trans but it is common to all the electronic solonoids in the trans so it seems ok if everything else is working. You could try an ohm meter with the wiring disconnected between t and e on the trans and see if the solonoid wiring is opened or shorted. It should read 21-33 ohms. If it isn't in this range it is prob the tcc solonoid.
Old 05-22-2009, 05:06 PM
syclone74's Avatar
Thanks so much for the info, I will try this, and yes this is the only code I am getting (p0740). So you think that if it was the wire that it would be kicking out some other codes to huh? I will let you know what I find out.
Old 05-22-2009, 05:09 PM
syclone74's Avatar
Is there a wiring diagram for a 98 so I know what pins to check?
Old 05-22-2009, 05:46 PM
spaz1's Avatar
it is the connector on top of the pass side of the transmission. pin E where the pink wire goes and pin T where the (tan and black) wire goes.
send me your email I'll send you the diagram. lucyandchris@shaw.ca
Old 05-23-2009, 12:28 PM
syclone74's Avatar
I dropped the pan and checked the ohms at the selonoid itself and the ohms were only 0.14 to 4.56. Does this mean the selonoid is bad?
Old 05-23-2009, 12:36 PM
LS1Tech Sponsor
performabuilt's Avatar
The TCC solenoid should measure between 18 and 26 ohms typically 22 ohms the numbers you have are to low so I would say you found the problem
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-23-2009, 12:40 PM
syclone74's Avatar
When you drop the pan is this the solenoid right by the trans plug? just want to make sure I checked the right part.
Old 05-23-2009, 02:19 PM
LS1Tech Sponsor
No its at the front and is help in by two 10mm bolts
The one at the plug is the PCS
__________________
Call 888-744-6542
Old 05-23-2009, 03:14 PM
syclone74's Avatar
Red face
Okay checked the tcc and there is no ohms reading at the selonoid. Must be bad right? should have a ohms reading
