What boost level will stock springs start to float ?
Old 05-22-2009, 03:33 AM
BigRich954RR's Avatar
Default What boost level will stock springs start to float ?
Ok with a stock cam how much boost can you run before the springs will let the valves start to float ? at around 6-6500 rpms?
Old 05-22-2009, 05:37 AM
EPP
EPP's Avatar
I've had stock valvesprings handle 15 psi before, but it is going to depend on your combination and how many miles you have on them. Bob
Old 05-22-2009, 12:27 PM
Sweet stock ls2 with maybe 25k miles
Old 05-22-2009, 12:50 PM
Dumb Ass Vette Moderator
ls1290's Avatar
The size of cam is going to be a big factor.
Old 05-22-2009, 12:55 PM
Chronicle's Avatar
If you already have your turbo setup installed and running, I'd just leave the boost at a low level (say 5-8 psi) and just buy the springs when you graduate from a stock cam.
Old 05-22-2009, 02:03 PM
black98ws6ta's Avatar
Ive made 500 rwhp on stock cams with a turbo car at 8-9 psi and started to see valve float. They will hold up in a supercharged car better since there will be less exhaust backpressure.
Old 05-22-2009, 02:27 PM
Restricted User
98Z28CobraKiller's Avatar
I think that mine are floating at about 15 psi and 6K RPM. Stock long block LQ9.
Old 05-23-2009, 09:23 PM
98catfish's Avatar
I dont think the boost makes much of a difference, Its the rpms that will be affected.
With a stock cam, why try to go over 6k or so your spinning it for no reason because you are not making any more power.
Quick Reply: What boost level will stock springs start to float ?
